cejsmith
I've now got my blower working so I thought I would get the a/c recharged.
Is the kwik fit deal any good? It seem like you can't lose.
Andy pretty certain they have to recover all the refridgerant to do vac test and they will put it back in plus some more if it needs it, if they used new gas all the time they would charge a lot more than £60.
Lynall
in his case marked 'OLD'
one month on from getting the Picasso re-gassed by KwikFit - the car isnt cold anymore.
they said they did a leak test before regassing.
car is going back there for them to look at it.
Their leak test is fairly useless unless there is a massive gaping hole in the system.
Futhermore they do not inject a dye in order to be able to trace the leak.
Looks like you will have to get a refund and take it to a specialist to trace the leak.
if they don't detect a leak, there is no need for dye
From what I've heard, if they do detect a leak, they just send you away to get it fixed.
Correct, they have no diagnostic training, equipment (or knowledge) to deal with any a/c faults, the fitters are simply trained how to hook up the machine, programme it and switch it on!........they didnt even programme it correctly on my first visit
......... the KF guy i went to thought that a/c systems worked solely under vacuum and was surprised to be told the system reached quite high pressures in operation.
