I'm looking for some advice on a 'click' that I have started to hear when I switch the ignition on.
From inside the car it sounds like it's coming from behind the passenger side fascia/glove compartment. It only happens when you first switch on the ignition - it clicks about 6 or 7 times, then you don't hear it again. I opened the bonnet to see where it's coming from and it appears to come from where the air conditioning 'black box' close to the bulkhead on the nearside.
I haven't investigated this any further yet, so can't add any more detail.
One thing. While the key is in the ignition, the 'clicks' won't be heard again... even if the engine is stopped and then re-started - even if the key is turned fully to 'off'. It's only once the key's been removed completely and you re-insert it that the click starts.
Any ideas??
Chris
Any ideas??
Chris
