Air Conditioning Smells A Bit Strange
D
Deleted member 37751
Guest
When I first turn the Air Con on, it emits a rather unpleasant smell at first.
The best way to describe the smell is you know when you were younger and you'd go to see a really old relative, well it's that smell...;)
Will it be the Pollen filters?
flango
Hardcore MB Enthusiast
Gods own country
Mercedes SLK R171
You need a can of THIS it's bacteria and mould in the air con system causing the exact smell you describe. There can also be virus's lurking in there so not good for your health. I'd run a can of cleaner through ASAP :thumb:
npuk
London
A180 CDI Avantgarde SE (2008)
Get something like the above, (ECP sell them and you get 25% off) but also use something like this AIRCO-BREEZE CAR AIR CON DEODORISING SANITIZER | eBay
I used to use the air con bombs but it would always come back after while so I got the above. Spraying it direct into the vents and intake etc makes a huge difference.
donubenz
Grimsby
w211 r230
Hi I also have a couple of Triumph TR's and was over in Lincoln picking up some bits from Rimmers the other day. They have a deal at the moment, £3.50 a can + p/p, to shift some stock
Air Con Cleaner - 500ml Aerosol at www.rimmerbros.co.uk
Note they also sell spares for Land rovers etc that have air con as TR's do not! My air con always seem to smell in Spring and Autumn for some reason?
Don
sarangimaster
S500 W140
I also had a nasty smell coming from my W140 air con, I changed the filters + used air con cleaner, seems to have done the trick!
Danny DeVito
Ireland
V220 CDI
No mention here about the drain pipe being blocked ? from the evaporator/ heater area ? I had this smell. i used spray stuff, it didn't really work. neither did the air con but the smell went away by itself after a few months.
