davidjpowell
Guys - I'm aware that we have a few business owners and landlords on here. Hopefully the below might be of interest.
PS - I'm a Surveyor I don't sell AC systems and have no vested interest!
The Issue
As most business operators and landlords seem unaware, there is a looming issue, which is going to affect businesses, and involve potentially huge bills.
This will affect most Air Conditioning systems installed before 2000, and smaller systems installed before 2004, where it is likely that a Liquid Gas Refrigerant known as R22 has been used.
Because this gas is harmful to the environment it has been illegal to put ‘virgin’ R22 into AC systems since 2010. From 1st January 2015 it will be illegal to introduce even recycled or recovered R22 into AC systems.
This means that any leaks in the system, or any maintenance that involves removing refrigerant would leave the system incapable of being restored to an operating condition.
The fix
There are replacement gasses. They will not mix well however with residues of R22. The effect of this is as a minimum seals and some equipment within the system would have to be replaced. Bearing in mind that the systems are often elderly it’s often more sensible to replace the whole system.
Replacing the seals or the system is disruptive to a business and expensive. In all but the smallest systems carrying out the work in working hours, unless the area is empty is most likely impossible.
Actions to take
Any business that is reliant on Air Conditioning for its processes needs to make a plan how to deal with this before January 2015.
Where the system is providing ‘comfort cooling’ a tenant/building owner may choose to forgoe the system. Tenants should be aware that after 1st January 2015 when a lease expires, a Landlord would have several arguments that would leave them footing the bill for conversion to a different refrigerant.
Other things to think about:
If you are acquiring premises ask the question. Take account of the cost of the work in your bid. My advice would be to convert any system before taking occupation.
Rent Reviews. If the system requires replacing would a tenant reflect the cost/liability of that in their rental bid?
The cost of the recycled refrigerant is already rising, and this will continue as it becomes scarcer.
The Issue
The fix
Actions to take
