Air elbow
Iceash
Great Bentley
CLK 230
Hi all,
I need to purchase the air elbow that connects the air pipe to the headlight for a w208.
Where can I get one?
Thanks,
Ash
I looked all over the country and ended up at the dealers in the end .So i would just go right there and save your self some time.. Or try a Rover BMC distributor advance and retard elbow.I purchased one from ebay last year .
As above MB is the best option they are not expensive, don't forget to get a pipe joiner as well, as the elbows will not fit the pipe easily. The excepted repair by MB for this scenario is to use a pipe joiner which is just short length of the correct size rubber pipe. You buy this pipe from the dealer by the metre and just cut a piece off you need.
Pipe joiner? On the other headlight it just pushes in?
