Air leak
Marku
Viano Ambiente 2.2CDI W639, S-Class 450SE W116
Got a persistent leak, about 10psi per week, from 225 55 R17 Goodyear on an MB alloy wheel. Tyre is getting on a bit but not at fault. Had it before and the tyre was taken off and the wheel rims cleaned and a sealer put on. That cured it but now it is back. What's the solution? Would having the wheel completely refurbished to the job? Have just read that the worst case is that the wheel cannot be saved. That true?
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
Yes and yes
How do you know the tyre is not at fault? Or is it the same tyre as when you had the wheel sealed before? If the rim has become porous you'll need to have it refurbished, powder coated.
Perhaps you could pick up a spare from eBay?
OP
OP
Marku
Marku
That was quick. Yes it is the same tyre. If it is porous will refurbishing cure it? Doubt getting a replacement on ebay they were an MB upgrade and not cheap.
