Air mass flow sensor
steveyboy
manchester
e220cdi 2009
Anyone tell me where air flow sensor is on a 2009 e220cdi and any other sensors for dpf problems,and is it doable for a diy.
alecmascot
North East UK
C220 CDI SE Blue Efficiency 61 plate
If you have a 651 engine: item 60
OP
OP
S
steveyboy
manchester
e220cdi 2009
No idea but thanks for diagram,dpfs are a problem second time I’ve had a problem 1st time garage cost a bomb,so thought I’d fit new sensor myself,is there any other sensors that are for the dpf.and why didn’t Mercedes fit a signal that pdf was working or not.🤬
mersum1es
Finland
W212, C219, W220
Any problem in boost line balance (inc. EGR) can trigger MAF fault, thats why it should be investigated by experienced garage... how you think MAF is culprit now? What symptoms/fault codes you have?
OP
OP
S
steveyboy
manchester
e220cdi 2009
last time i had it done at garage came up with dpf kaput had it done then a few days later engine light came on again,back to garage another £65+vat for diagnostic came up with mass air flow another bill.so that is why i no longer wish to go down garage route again i had my local indie do a forced regen and engine light came on again,so thats why i am asking for any answers to mass flow and any other sensors plus where situated and will replace one by one myself.
