Mistermackay3
Hi, I have had two plastics links break on two long journeys. Can metal lowering links replace the plastic ones or are we talking about two different thing? Thanks Colin
The drivers side wheel went down to the blocks once and on the second ocaasion the nearside rear went right down. Each time the garage said it was the plastic rods that had broken. ColinWhen they broke what happened to the suspension?
There is a plastic rod on the sensor which is connected to the body by a steel rod (on my car)...the lowering links replace the steel rod. If the plastic arm on the sensor is broken then the lowering links will not work.
What year is your car?[/QUOTE
Hi, I have checked their invoice and they replaced the front level sensor rods which had snapped. From what you are saying, the metal lowering links are not the same thing and it would therefore be pointless buying the metal lowering links. My car is a 2007 model. I take it that the sensors always have a plastic rod and they have not been modified. Colin
