Given lots of airbags went off, then its unlikely it was a failure in a single bag.
Therefore, the airbag unit must have 'decided (by design, or by error -software or hardware-) to ignite the airbags.
If it was design, its because it had a set of factors occur that made it do it. Now either those factors really occured, or it thought they did because of 1 or more sensors failing.
If it was software error, I suspect there would be lots more reported cases.
So, I would put this down to hardware error, with one or more of the airbag controller and/or any/all sensors.
However, if i remember right, the airbag units have a 'control unit log' and do keep info of why/when/what-speed this hapenned at..
So MB dealer really ought be able to find out what sensor triggered it, and should be replacing other stuff (which of course they may be)
What worries me, is that if you don't find out why then it will happen again. I.e some hardware is broken and the same set of circumstances will occur again.
I presume you are talking to your insurance company. Normally airbag deployment == write off.
R
R
