Paul SL320
- Mar 9, 2011
- SL320 1998
It’s taken me some time to narrow down, but this highly unlikely scenario has recently started on my 1997 SL320 with standard non-Bose hi-fi system.
By setting the Climate control unit to diagnostic mode I can see the temperature of the refrigerant at the aircon evaporator varying between 3°C and 8°C on my car. When the temperature climbs up to 8°C the expansion valve opens up a bit and makes a gently hissing sound for a few seconds. I can see the refrigerant temperature start to drop down 3°C again.
As soon as the expansion valves gentle hiss stops, more times than not, I get a static type crackling sound from the passenger speaker. The crackle lasts about 1 to 2 seconds. The crackle sounds like the type of sound you get from the speaker of your home stereo system if you play around with its speaker wire while the amp is powered up.
If I switch off the aircon the speaker crackle never occurs.
I have disconnected the plug to the amplifier located under the rear seat base. The speaker crackle still occurs.
I have removed the stereo head unit from the car, so that the harness that plugs into the head unit is left open ended. Still the speaker crackle occurs.
I think that somehow the speaker cable is either picking up electromagnetic interference from an electrical actuator on the aircon system or the speaker wire and aircon system wire has become bared in a place where they both touch.
However I’m not really sure what goes on in the aircon system when the evaporator temperature reaches 8°C and the system decides to cool the refrigerant down. Can anyone confirm?
Or possibly an electrical device on the aircon system has a bad earth that somehow is feeding current into the cars electrical system via the earth and manifesting itself as a speaker crackle. Does anyone know where the aircon systems earth is located?
Or, is the expansion valve controlled by vacuum, and its a vacuum leak to the central locking actuator in the door that I am hearing?
Any help or suggestions would be greatly appreciated.
Regards
Paul
Regards
Paul
