Can someone help please! It looks like, something not quite right with my aircon on the Viano. It needed a small amount of recharge as it was not cooling... Apparently only needed a little refrigerant to make it cool.
The analogue pressure gauges now show 18c outside & Engine ide: moving between 25-35psi on low side and simultaneously on the high side 150-250psi Engine on idle, Both gauges crawl up simultaneously and come down between the above figures...
The aircon guy reckons it’s too high of a reading on the high side and might be the expansion valve playing up and needs changing.
I plugged my star software on and states, that the max acceptable pressure is 360psi compressor runs 86-96% again on idle but Star says it should ne 100%. evaporator temp 3.5-6c pressure fluctuates between 10 -17Bar (150-250psi)
Anyone who can tell me if the above readings are ok, or does it need attention? And if so where do we look???
Help greatly appreciated!!!
Thanks in advance!!!
