fred_raven
Ok so have a problem with my w211 aircon! hadnt been regassed for a while and was getting to the point of only just working, tried a diy regas kit but didnt really work ! Whilst doing this and with help from guy who sold kit to me discoveredthe following , pressure at low point too high ( 60 - 70 psi) and not reducing when aircon is turned on , or off for that matter! There is no clicking sound when aircon is switched on so suggested that a check on voltage at compressor , starts at 1.3v even when off , when switched on goes up to 13v but soon drops again to 1.3v , after 20 secs or so goes up to 13v again for cpl secs then back down to 1.3v ! Had read that the gas should be replaced and this probably hasnt been done so went to kwikfit , who did a full drain test and refil and after a quick check when starting the car decided it wasnt fixed so ... NO COST !, techie did check and said compressor is turning ! on drive home car was getting much cooler tho ! but have since discovered that when car is only ticking over car lets out warm air !! so my guess is there is a problem with one of the sensors but ! Any ideas gratefully recieved!
