Evaporator leaks are rare. Not completely unheard of, but rare. Condensor leaks are the most common - it lives in a harsh environment, with stone chips, road salt, dirt and leaf mould all playing a part. Compressor faults are the second most common, moving parts and seals that can and do fail. Have you had it diagnosed as the evaporator?
See post #2 above........or take the dealers word for it.hello, what else could it be if not evaporator leak ?
We should not have to refill any aircon gas in a correct system.
You insert a sniffer in the vent which will detect refrigerant. If they were able to detect it, then yes it's the evaporator and yes, you can't get to it without removing the dash.
Thank you, so only the evaporator is a real problem to change.
and if no refrigerant gas in the vent, it means that the problem is the condenser in front of the car ?
If you are not confident of the dealer diagnosis then get a second opinion from an AC specialist. There are plenty about. The evaporator is by far the worst item to replace. Our 124 is now back and fully sorted. Roughly 15 hours labour to complete the job - a couple of other minor issues were found unrelated to the AC once it was all taken apart.
You can smell R134 a/c gas in the car or use a gas sniffer, you can also check the evaporator drains for dye if it’s been added to the system. Replaced a few now and heater matrixes.
