french
- Dec 3, 2006
- Audi TT RS 2.5 , Zanussi Wd12: - LG Combi Multiwave - Swan 9 slice toaster with removable crumb tray
Over the past 2 weeks my E55 has been showing me "Airmatics visit workshop"?
I had no previous warnings & the car had run perfect when last used , which was about 2 weeks before that.
I put a diag on it & it said Front left damper unit on Y2 had two wires touching?
Ok so I had a look at wires & they looked new from the unit, I separated the plug by the Strut & sprayed contact cleaner & I put a diag on & it said the same again?
Same at the N51 Suspension ECU, plugged it in same error...So after playing around I gave up, before I did I put the C tek on for a day, came out in the morning & the C tek showed the green light with the battery fully charged, tried again & got to the bottom of the road & up came the "Airmatics visit workshop", now before I pulled away the suspension works as it should , Comfort, Sport 1 ,Sport 2 shows up & it raises to the full height?
I thought I'll take it to a garage that has the proper Star equipment & someone who knows how to operate it correctly, so I went there yesterday & up came a load of codes (?) plus the one my machine had shown previously, they said they would clear all codes.
Drove out the garage & up it popped again, they had a look & said all the other had gone so it must be a strut, I asked how it has not dropped in height ever, he said the air part is OK its the damper solenoid thats U.S. & they cannot be repaired so a new strut needed.... Eeek!
When I got home I a friend popped over & I told him my day, he said, " Has the battery been flat at all as this will give spurious codes", I said I had fully charged it two days ago & had just done a 25 mile round trip that day so we had a look with the multi meter 12.38v...he said could be better.
He then told me to not touch the car at all & check the voltage tomorrow afternoon & see what the Volts are then. Next day unlock it( now at this point there was no Airmatics visit workshop showing) so look at the Volts 11.9 & right away up came the "Airmatics visit workshop"...he said your battery is suspect, switched the engine on & 14.1v, so cleared code, engine running , went for a short ride to Halfords about 6 miles , came out it showed 12.2, went to friends house about 20 miles & 26 miles back, all the jouneys the Airmatics suspension was perfect, I went into corners fast to try & aggrevate it but perfect in all settings came home stopped car & it showed 12.3v.
Now my friends has told me that if the Airmatic system see's under 12 v(11.9v) it will trip it into Limp mode until you turn off , he is right on the ball
! Plus as its suddenly got a lot colder & the car was not used for a few weeks this combination is the problem, solution...I am going to invest in a new qualityAGM battery...plus a drink for my (bestest now mate)
So hope this is useful to someone in the future, ...Phew am I happy!
