Does anyone know anything about sterling alarms?
Reason mine is out of sequence and I do not know what happened.
Initially it has 2 buttons on the fob. One above and one below.
To arm it you press the top button once and a beep follows then a red light on the dash flashes once every 3 secs.
To disarm, you press the top button again, it beeps twice and the red light flashes continuously until you open a door then it goes out. If you do not open a door or boot, it will arm itself again after 30 seconds thinking it was an accidental press of the button.
if a door is left open while trying to arm it beeps four times
Now what happens is this (just started one saturday afternoon)
To arm press the top button and it beeps three times followed by the red light on the dash every 3secs.
To disarm you press the top button and it beeps twice but the red light just goes off and does not arm itself if you do not open any doors, so if you accidentally hit the button from the house, it could stay disarmed all day.
Do not ask me what the button below is for as it has never been used.
Each beep comes with the indicator flash.
Any ideas welcome as it needs resetting I think.
