Hi all,
Not sure if this has been mentioned here before....and not sure what section as its engine & electrical....
Well after 120k miles of trouble free motoring I have hit a BIG problem
Car (2001 W210 E200k) had started surging at motorway speeds 70-80mph and also surging at idle with aircon on. Engine light is also on.
This is a KNOW fault on this particular engine!!
Right now the root of the problem, camshaft magnetic sensor (at front of engine) has a manufacturing fault where on some occasions it will pass engine oil through the electrical connections of the sensor right through the engine wiring loom all around the engine bay up to the ECU if you don't catch it early enough it will flood the ECU blowing it
Fix = Complete engine wiring loom, Co2 sensor, modified camshaft sensor & a mod loom (to stop the oil passing through) and if you are unlucky (luckly not me) an engine ECU Just seen a bill for a SLK 200k at £1300 from main dealer just for engine loom and sensors inc labour (ECU was ok) ECU is about another £700 on top.
I was lucky that me and my Merc man spottted the oil at the ECU multiplug early (as he has seen this before)
Car is now in for repair (4-5 hour job) luckly parts are only around the £400 mark and labour is free
So if you have this engine type (in any model) please, please check this with your dealer, if you fit the mod loom (about £20) this will stop the oil passing up the loom.
Missing it already!!
