Alloy Wheels Tyres Deflating
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by jellafish, Apr 30, 2014.
  1. jellafish
    jellafish New Member
    25
    May 8, 2009
    Cumbria
    Car:
    E300 TD Estate 1998 7 seater W210
    Recently replaced all 4 alloy wheels on my S210 with steel wheels and tyres.Sick of having to keep inflating them on a weekly basis because they were losing pressure.
    Local garage buffed inside the wheel to try and cure,leak did not show in a tank of water,put down to slight ovaling creating slow leak.
    Once steel wheels fitted tyre pressure remain constant.
    Anyone else have slow tyre deflation with alloy wheels and does a wheel refurbish cure this type of problem.
  2. StevenN
    StevenN Hardcore MB Enthusiast
    437
    Sep 12, 2010
    Nottingham
    Car:
    E220 CDI 2002 W210 Auto
    I had a problem with a couple of wheels last year.
    Simply got my friendly tyre fitter to remove the tyre apply some bead sealant then refit the tyre.
    All sorted. Can go weeks before they need air.
  3. GordonTarling
    GordonTarling Hardcore MB Enthusiast
    1,596
    Jun 29, 2004
    Grantham
    Car:
    2007 E63 AMG V8 Estate
    I had a similar problem last year. The local garage re-sealed the tyre bead, but it still continued to leak slowly. Had them refurbed over the winter and they're back on now, with no leaks evident. The main problem seems to be that salty water creeps in between the bead and the rim, causing corrosion over a period of time.
  4. Neil Mackay
    Neil Mackay Hardcore MB Enthusiast
    859
    Nov 17, 2011
    Car:
    C32 AMG Estate
    As above, bead seal does the trick! Mine hardly ever need topping up now where as before I was doing it every other day!! Most tyre places have bead seal on a shelf in their fitting shop! Even the mobile guys do!
  5. brucemillar
    brucemillar MB Club Veteran
    7,733
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    Bead Sealant is good for this. However some alloys have been known to be corroded or cracked.
  6. p3tchy
    p3tchy Hardcore MB Enthusiast
    223
    Aug 13, 2013
    Milton Keynes
    Car:
    CLK W209, K6 GSXR 1000
    Cracking is the most common reason, Pretty much every set of alloys I've had has cracked at some point. the only ones so far (touch wood) are the SL 18's I have on atm.
  7. Howard
    Howard MB Club Veteran
    18,624
    Apr 23, 2004
    Toad Hall
    Car:
    CLS 500 / A 150
    It's weird because I've never and I mean never had even a single alloy wheel crack on me.
    I've AMG's , Brabus , mercedes , BBS , vw , Honda , you name it ... Never a crack
  8. brucemillar
    7,733
    Nov 18, 2010
    Car:
    Now you just know what will happen next..
    1 person likes this.
  9. Howard
    18,624
    Apr 23, 2004
    Toad Hall
    Car:
    CLS 500 / A 150
    Pssssssssssssssssssssssssssss
  10. johnsco
    johnsco Hardcore MB Enthusiast
    1,855
    Nov 22, 2008
    Leeds, West Yorkshire
    Car:
    E280CDI SPORTS ESTATE
    In the last 10 years, I have had all these alloys wheels blasted and refinished because they were losing pressure.
    Tried using sealants to no avail
    All were due to corrosion
    W210 E300TD 1998 ... All 4 wheels
    W210 E430 2002 ... All 4 wheels
    All wheels were subsequently cured of the problem ... As well as looking smarter.
    No wheels were found to be cracked.
  11. renault12ts
    renault12ts MB Club Veteran
    14,679
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    This happened with my wife's Rav4 until two years ago when I bought a can of Holts Tyre Weld...problem solved.
Share This Page
