Alloy Whes.
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by johnlewis1964, Aug 27, 2017.
  1. johnlewis1964
    johnlewis1964 Active Member
    140
    Aug 17, 2017
    Car:
    2008 C180 Kompressor.
    Hi folks will 18 inch wheels from an s class fit my c180 2008 w204 many thanks.
    I bought a set of wheels 18 x 8 et 45 5 x 112 but they won't fit flush on hub hitting shock did I buy the wrong wheels it's my first Merc.
  2. PobodY
    PobodY MB Enthusiast
    2,523
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    CLK350 Sport, Nissan GTiR
    The offset is probably wrong despite the PCD and centre bore being correct.
    You can do what I did with my winter wheels and just fit a spacer behind them to keep them from fouling the suspension (in my case, the brake calliper).
  3. OP
    OP
    johnlewis1964
    140
    Aug 17, 2017
    Car:
    Will that do it do you thing what width spacer cheers.
  4. OP
    OP
    johnlewis1964
    140
    Aug 17, 2017
    Car:
    What are a good make of spacer will I need longer bolts many thanks
  5. AMGeed
    AMGeed Hardcore MB Enthusiast
    12,803
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2014 E63 Biturbo
  6. OP
    OP
    johnlewis1964
    140
    Aug 17, 2017
    Car:
    Many thanks.
  7. AMGeed
    12,803
    Nov 1, 2008
    Car:
    2014 E63 Biturbo
    Correction to the above. S class wheels have an ET 45. W204 C Class rear wheels the ET should be 54.
    In theory, the S class wheel should sit 9mm further out toward the bodywork so a huncentric spacer shouldn't be required.
    Apologies for the error.
    Here is a chart to double check any wheel you want to fit and what you already have.
    http://www.alloywheelsdirect.net/mercedes_alloy_wheels
  8. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    Will they have low profile tyres on? So the overall rolling radius won't change?
    If it is going to increase, your speedo will be wrong and you'll lose acceleration.
  9. PobodY
    2,523
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    The error in the speedometer is small enough to be insignificant. - Changing from 14" to 16" wheels on my Nissan means that the speedometer reads 115mph instead of 112mph when the limiter kicks-in.
  10. renault12ts
    renault12ts MB Club Veteran
    15,973
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    But, if they are touching the shock they will need spacers.
  11. OP
    OP
    johnlewis1964
    140
    Aug 17, 2017
    Car:
    I had a look at tyres and they are 255 x 45 x 18 could that be the issue many thanks.
  12. Mr Filipov
    Mr Filipov Active Member
    335
    Dec 30, 2015
    Car:
    2017 BMW 535d Gran Turismo
  13. renault12ts
    15,973
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Yep they should be 225/40. Those are too wide and too tall. Each side wall is an inch higher than standard...so the diameter is 2 inches too big.
  14. OP
    OP
    johnlewis1964
    140
    Aug 17, 2017
    Car:
    Thanks guys so 225 x 40 front and back cheers thanks for all you help.
Tags:
Share This Page
