I would like some help with heating system set up please- I am looking into my options....
Current set up:
-Pressurised system run off oil fired boiler running hot water & house heating
-Large house served currently by large capacity old style(but less than 5yrs old) rads in steel with the 'large column cast iron look'
-Rads vary from 5-8kw each (large rooms). Do not have TRVs currently
-Currently 15 rads, but need another 3 at least
I wish to supplement the oil system, ideally with;
-A wood fired stove with integrated back boiler. I like the stovax stoves which have integrated boilers rated upto 8-15kw(in addition to 4-7kw for room heat) depending on model of stove
I realise the house will need much more than just the 15kw max stove boiler output, but would like to use this to supplement/top up the main oil boiler.
This is likely to be in a main family room (fairly close to the boiler/hot water tank) & as such the stove will be used most of the daytime over the winter
AND
-A ground source heat pump
I mainly wish to supplement the house heating as this is the main expense & requires much more energy than the water heating
I know underfloor heating is the ideal for groundsource heat pumps, but this is an old house with many wooden floors so not a feasible option, although I understand large volume rads are next best thing
Questions:
-Is it possible to supplement the energy source whilst retaining the current pressurised sytem? If so how would they interface?
-If not possible, then is the easiest way to separate the heating & hot water systems & change the heating system to a non pressurised, vented system(I understand the stove needs a vented system), whilst retaining the pressurised system for the hot water? What are the problems with this?
-Is it feasible to have 3 heat sources on one system? What are the drawbacks. What kind of controller will be required?
-Would it be better to keep things simple & use just 2 heat sources? If this is the case, then my choice would be the stove/backboiler combined with the oil boiler. -Any problems with this?
-To minimise initial outlay, is it possible to put in the stove/backboiler first, but with the option of adding groundsource heat pump in a couple of years? Will this make it difficult to balance the system later?
What else is there to be aware of?
Alternatively, are there any good forums for this kind of stuff?
I realise this is rather niche/specialist- many thanks for any pointers/help/advice
Matt
Current set up:
AND
Questions:
Matt
