dougl65
For those who like OE looking equipment I have just installed a Becker Cascade into my R129 SL. This is available from Pixmania at a good price.
As Mercedes used Becker as an OE supplier the functions on the Becker are similar to a Mercedes comand unit with linguatronic functionality, indeed the commands to operate the Becker are the same as linguatronic. You get a colour screen MP3 capability, ipod capability etc for around £650 - £800 depending on the version! The Pro 7941 version has better phone functionality along with a SIM and SD slot whereas the 7941 has bluetooth only!
The installation is really simple too: micrphone, gps antenna and plug in the connector. Just make sure that you have a speed sensor wire installed in position A1 and that if there is a wire in position A2 (diagnostic wire) that you cut and isolate this wire. You can also buy an external source connector made by Blaupunkt from bluespot.co.uk which plugs into the C connector with the micrphone for around £7 if you don't want to spend an extra £100 or so on the ipod interface..
Sitting beneath the Climate control unit this looks as if it were meant to be there!
Doug
Doug
