Am I right if I say that the MAS sensor ...
Msmax
Holland
Mercedes E-290 TurboDiesel
Please help me out with this.
Have read a lot about the MAS sensor giving all kind of problems.
But is it true that for diesel engines ONLY the CDI types have these fitted?
Seems the TurboDiesels don't have one.
Steve_Perry
Wales, U.K.
CLS350CDI Grand Edition
I'm afraid I only know a little about the MAS as fitted to petrol units. Maybe Dieselman will be able to help you?
S.
jimmy
Northamptonshire
Discovery 3 TDV6, Discovery 300TDi - Plaything!
My C250TD has a sensor on the top charge pipe that runs along the top of the radiator, it is a air temperature sensor. Slightly different to a MAS sensor.
I don't know about the CDi engines I'm afraid.
Dieselman
Banned
Peugeot 403 Convertible
E 300 turbos deffinately do have a MAS.
All electronically controlled diesels or petrols need a method of knowing how much air is being drawn into the engine.
Older petrol EFI units used to use vane type air flow sensors but they can't account for air density, so the MAS was born.
OP
OP
Msmax
Msmax
Holland
Hi Dieselman,
Mine is a E-290 TurboDiesel. I checked under the hood and I think I found it.
This sensor is mounted between the air filter and the turbo.
A temp sensor is mounted between the intercooler and the inlet manifold.
Is there a way to test the sensor?
When should it be replaced?
Dieselman
Banned
I'm sure Bosh has given guidelines for testing the MAS but you would need a variable airstream and temperature and then measure the output. In reality there is no test.
Replace the MAS if the car has no go and isn't fuelling up.
Dieselman
Banned
Info for all 200 / 230 owners.
It should be possible to use the MAF for a VW 2.0 litre petrol. Bosch no. 06A 906 461A.
Price about £50.
