Bellow
Hardcore MB Enthusiast
What! Isn't that how everyone quotes them?
I'm 5 foot and 200mm tall and weigh 8 stone and 3kg. Makes perfect sense don't you think?
My bad I get it nowI'm 5 foot and 200mm tall and weigh 8 stone and 3kg. Makes perfect sense don't you think?
My bad I get it now
*Technically speaking* the last “proper” AMG was the C36/E36 model of the early 90’s.f
Technically speaking no AMG can be called a 'real' AMG (including my own C55) if it was made after 1st January 2005. That's the day Mr Aufrecht sold his remaining shares in AMG to DaimlerChrysler and AMG as a separate entity ceased to exist.
You can do whatever you want, it’s your car... stick a BMW badge on it if you want buddySo if I new AMG is not a proper AMG,and my AMG sport is not a proper AMG,can I leave the AMG edition badge on?
Neither are real AMGs just lower spec look alikes, I can tell because they are missing the AMG badges ;-).
A whole new level.It isn't just combining imperial and SI units that makes it stupid.
At 5250 rpm, power in hp and torque in lb.ft are exactly the same and the two when plotted on a graph will cross at 5250rpm. So, with a Pmax @ xxxx rpm, Tmax @ xxxx rpm and lines drawn from each to their intersaction at 5250 rpm, you can as good as draw the graphs (in your head) from the two headline figures and the rpm at which they occur. Only when the units are imperial though.
Go metric by all means (and lose the above) but quote power in kW - too weedy for the needy?
Well we buy fuel in litres but talk about miles per gallon...
We like it because the non-British find it difficult to use.Not only this post but all the other discussing mixed systems ......
Why do the British people insist on continuing to use the archaic and difficult to use imperial system.
Because going over wholesale to the metric measurement system is seen by many as losing something that is thought of as 'British' and part of our way of life. Whereas the metric system is considered 'foreign'.Not only this post but all the other discussing mixed systems ......
