RattlerRattler
- Sep 26, 2013
- SL 55
AMG brake calipers, discs and pads from a SL55.
I bought these from a forum member - cb1965 - earlier this year to replace my disks and calipers on my SL55, I had worn disks and wanted to paint my calipers and these seemed an ideal way of sorting both out. But these are different to my original disks (mine were the later, floating disks and different calipers on my 2007 SL) but could have swapped for these as they are compatible. But I managed to source some original spec replacement disks from elsewhere, so these disks, calipers and pads are now surplus to requirements.
These may fit other models too, but please check / search - all relevant details are below.
Details;
Calipers: Good overall condition. Functionality wise they are perfect with no sticking pistons etc. The seals are in great order and the plates at either end of the caliper have no corrosion or noticeable wear. Cosmetically they are very good, but not new obviously so there are some light marks consistent with any caliper of this age.
Caliper numbers-
Front: 20.7919.01/20.7919.00
Front carriers: 19.7661.04
Rear: 20.8042.00/20.8042.01
Note that these are Brembo part numbers as the Mercedes numbers are not stamped on Brembo calipers. To find if these fit other cars than the R230 SL you will need to search these part numbers in Google.
The front carriers do unbolt and for some models this caliper is used with a different carrier. Again search in Google or contact Brembo fro fitments.
Discs: New in 2013 these are in excellent order with no measurable wear whatsoever.
Pads: Brand new Mintex pads - boxed, never fitted.
Price: £1100 ovno
These are heavy and would be expensive to post, so collection from Camberley, Surrey is best. I will put these on Ebay shortly but wanted to check interest here first.
[/QUOTE]
Tim
Details;
Caliper numbers-
Price: £1100 ovno
Tim
