As above people , they were removed from my W219 Grand Edition around a year ago when i fitted a new set of aftermarket 19" wheels.
20160815_094901_zpsi19wkviw by Kenny Niven, on Flickr
Fronts - 18" x 8.5" with a 25mm offset - AMG B66030086
Rears - 18" x 9.5" with a 28mm offset - AMG B66030087
18" AMG VI wheels in High Sheen with Titanium Grey - Alloy Wheels Direct (50318)
They have been dry stored in work since removal and just one wheel has lost air , the other three still have 32 psi in them. I never had any issues with vibration or balancing issues , they have never been welded or repaired in my 4.5 years of ownership but they could be doing with a refurb as some of the lacquer has moisture marks on them and there is the usual corrosion around the centre caps . They come with the original wheel bolts and MB security bolts / two security sockets.
wheel1 by Kenny Niven, on Flickr
wheel1a by Kenny Niven, on Flickr
wheel2 by Kenny Niven, on Flickr
wheel2a by Kenny Niven, on Flickr
wheel3 by Kenny Niven, on Flickr
wheel3a by Kenny Niven, on Flickr
wheel4 by Kenny Niven, on Flickr
wheel4a by Kenny Niven, on Flickr
20180513_121618 by Kenny Niven, on Flickr
20180513_194150 by Kenny Niven, on Flickr
This listing is for the wheels ONLY , you can make your own decision about the tyres ,which are :
Rear - Continental SC 3 - 275 / 35 / 18
Front - Evergreens ???? - 245 / 40 / 18
These tyres were new when i got the car 4.5 years ago and at the time of removal they had covered around 18k miles.
If you are local to the Glasgow area then they can be picked up , if not then Paisley Freight seem to get a good name as a national courier which is handy as i live in Paisley and can drop them off if it will save the purchaser some cash.
£400 picked up , courier at your expense.
Cheers - Kenny
Cheers - Kenny
