There are some very intelligent people lurking on this forum (no not you, Howard ) so have theoretical challenge:
It seems pretty straightforward - supply vehicle speed or mass air flow and alter the pump voltage based on a map. Alternatively an adaptive system that measures rate of change in inlet air temperature and learns what effect altering the pump voltage has. How do you go from a laptop with software to do this (which I can do) to a microchip in a box (which I can't)?
Is this a waste of time?
- How easy would it be to create a variable flow-rate in an air-to-water charge cooler?
- Is it actually worth it?
