Steve Holland
- Dec 23, 2011
- Location
- Manchester, Lancs
- Mercedes C180 Classic Estate 1996 and a Ducati Paso 907ie in the Garage.
Hi recent newbie with few other threads ongoing re my 1996 C180 with an auto box 722.6 version fitted.
My regular corner shop local parts man whom I have used for 15 plus years has in stock with the following on the bottle.
Comma ATF.
AQ3
Meets Dexron III
Meets specs for GM Type a Suffix, Dexron ÍID / IIE / III,
Ford M2C-138-CJ/M2C-166H,
ZF TE ML 09/14,
ALLISON C4.
£6.99 a litre.
The question is will this be okay to use in the gearbox?
It may be for only a short period as there is a fault with the box and I am going get things checked out in the new year, however having checked the level as per the specs and routine I am a a little low so the fault may be here or associated so I am going to top up.
We have checked the shop books and this is recommended in despatches so to speak however as he said suppliers are " a little delicate when recommending fluids for MB's due some aggresive MB marketing of their own make products".
Have I found a suitable replacement?
Comma ATF.
AQ3
Meets Dexron III
ZF TE ML 09/14,
ALLISON C4.
£6.99 a litre.
