Danny DeVito
On the gable wall of my bungalow, would the cavity be closed at the top ? Or might i be able to look into the cavity if i remove some tiles ? House built in 88
If you want to look into the cavity on the gable for what ever reason i wouldnt want to disturb the roof so cut an hole in the internal skin located within the roof space. Easy to repair and no chance of ingress.
I got my hygrometer from hongkong today it shows 69% humidity and 19c in my bedroom. Much the same since about 4 pm today. 69 seems a bit high.
Insulation is not very tight to the eaves but they did fit 10 roof vents to compensate anyway
Can you post a photo of:Air vents are fitted into the roof now, 5 each side. They remove a tile and cut the felt underneath. The vent sticks up then replacing the removed tile. First visit they put them too low, now they have moved them up it seems to be helping a bit. the mold is not returning very fast except where it has penetrated the surface. Humidity is generally about 65-75 % Still very high. With all windows wide open it dropped to 55% at 17c. This was on a very VERy windy day. I havent looked into the cold spot yet
