Another duo valve question?
portzy
Ulrome, Driffield, East Yorkshire.
An SLK R171 with lots of toys and a Golf Plus for fishing.
Are these little devices supposed to be either on or off or, do they gradually open/close as the individual temperatures reach that which is set on the dash?.
One of mine is cyclically opening and closing about once every second or so and its doing it with a very pronounced and audible, (inside the car), noise, something along the lines of a "ker-thunk", which you can also feel slightly through the steering wheel, if you can imagine that. Its only just started to make itself apparent, is this right? or just wear and tear?.
Cheers.
Portzy.
Hi, yes I'd seen your 'how to' but I wondered if the valves were either fully on or fully off but you have answered that for me. A dash temp selector fault eh?, do you reckon that would be stored in the diagnostics computer so they could detect what is wrong.
Portzy.
They open and close all the time, depends on the heat setting too. You can feel them kerchunk, kerchunk.....
Noise also comes from fuel pump pipes in their holder on firewall as pump cycles.
Bazzle
