ontheball247
Hi I know there are loads of threads out there about W202 alarms that randomly go off, but non of them seem to give a definitive answer as to how to actually just disconnect the alarm. Well, except for one that tells you to disconnect the two smaller connectors on the module behind the carpet on the right side of the boot (ie. in the right side quarter panel) and then says that didn't work, so you actually need to disconnect a module further back in the boot, which I don't have.
Now first of all, I have a 1998 S reg W202 C250 TD and the alarm seems to go off randomly while the car is parked up, and sometimes simply walking past the car triggers it. But only my hazards flash, which suggests the previous owner disconnected the siren at some point. Also, there is a little plastic bracket next to the fuse box in the boot (next to the spare wheel) which another member seems to have a little green box attached to, with wires coming out of the bottom of it. But I only have loose wires going up to the bracket from underneath it, that aren't connected to anything.
Secondly, the reason I just want to disconnect the alarm altogether is because I'm not willing to spend any more money on the car. I've just spent loads on small annoying issues and spending more would not be viable considering the age and value of the car. So I simply just want to disconnect the alarm now. What's more, it seems to be popping off a lot more now than it used to and its draining the battery more and more frequently.
Can anyone help? I'm looking for either a quick cheap fix (which I know is hard to say without checking the car), or how to disconnect the alarm altogether.
Thanks a lot.
Baz.
Thanks a lot.
Baz.
