Antenna amp.
Robbiejoanne
County Durham UK
M:L320
the antenna amp is powered by the headunit so you do need to connect the relevant cable to the antenna adapter but otherwise it was plug and play. i am having the problem above. How do i find out which is the correct cable i connect to? I have a 2008 ML320 W164
I assume the HU is after market, the output to your amp is usually blue.
To find the wire in the loom to connect that to it's easiest to re instal the original HU, When switching the HU on and off look for the output that is provided with +12v, that's to the amp.
