Hi all,
Please will you advise. I am replacing my stabilizer links/rods with Lemdorfer ones. - 35264 01 and 35263 01. ( OEN A 204 320 04 89) The lower part which is the rubber part - pic - Q: what bolt replacement do I need - I have looked on ZF and emailed Lemdorfer as they do advise to replace bolts when replacing links etc. Which is prudent! However, they do not have it in their catalogue - Is it M10x1.5 hex bolt not sure length, probably up to 50mm? I can just take it off and check under the car and replace at a later date but I would rather have the new bolts to start with. Happy to go with another manufacturer . Febi? Thanks
