Chrishazle
- Nov 13, 2008
- Location
- Nr Ashford, Kent
- 2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
This is the first house we have ever owned that has a 3 phase electrical supply, normally not a problem but tonight for the first time we have had a power cut with a foible, so I'm hoping someone can advise.
Any power cut in the past - and there's been a few in our 12+ years here - once the power comes back on it's the whole lot. Tonight the power came back on, I noticed that our living room incandescents were dim, our oven and hob would not fire up, and a couple of other things. By investigation I figured that Red phase was on at lower than normal voltage, although the other 2 phases (Blue and Yellow) appeared to be fine. However, not being able to use the hob and oven when ready to cook dinner was awkward, to put it mildly! Reported it to Ukpowernetworks, over the next couple of hours Red phase was on and off, managed to get the veg's cooked and into the warmer, but ended up cooking the steaks on a camping-gaz stove!
So - in my consumer unit cupboard I have one consumer unit for each phase, plus a seperate circuit breaker for the cooker, which I'm now certain is only fed from Red phase.
Is it possible to install a selector switch upstream of the cooker circuit breaker so I can select which phase feeds it? How do I find an electrician qualified to work on 3 phase and install it? (I ask because a few years ago BG turned up to install Smart Meters, fellow took one look and said "that's 3 phase, I'm not qualified to work on that", then said "there's not a domestic 3 phase SMETS2 meter yet, don't know when one will be available!!", so we're still on an ordinary E7 meter (and not with BG!).
Any help appreciated!
