Max M4X WW
- Mar 21, 2013
- 190E LE Azzuro
Hi all,
I am new here and this is the first problem I have had with the car, as it started before I bought it! I will try and keep this brief, but any help welcome!
When I viewed the car before purchasing I realised the air con would not turn on. We found a fault code stored for a flap actuator which was cleared and the system was then re-gassed as it still didn't seem cold.
The air-con seemed to be working (thought it was sub 10oC outside so difficult to tell!) and I bought the car. Everything seemed fine but a week later it wouldn't turn on again. A new fault code was showing for the evap core sensor which I replaced with a FEBI item.
This fault code now displays every few days and goes when I clear it. The air con isn't working as now with the warmer weather it doesn't seem cold. I ran the extra diagnostic with all the values and the refrigerant pressure on the diagnostic display is 4.2 bar with the engine both at idle and not running. This seems low?
Just wondering where to start really! How can I check the compressor is running? Normally they click in and out but I'm told the air-con is never 100% off on these cars (if working!)
Thanks, Max
Thanks, Max
