Pretty much everything’s possible if you chuck enough money at it..
Cheers,
Gaz
Why not have this conversation with your local planning department? Would be surprised if they were not prepared give you an indication of wether or not they would be likely to give Planning Permission or if there are going to be any major issues.
Well it is detached and so the size of the extension is not a problem you will not need planning but will need building regs,the side of your proposed extension must be 1 meter from your side boundary ,I suggest that the extension roof will have to be different,possible a slope front and back breaking into the exisiting roof,find yourself a decent architect,as it is a local property do not use the one in Dovercourt,my other suggestion is that when you get the plans drawn up pick Shore to do the building control they are more expensive by about £150 than the council building inspector but he is a local and a tree nut with the amount of trees on your boundary he will have you digging to OZ.
What about the street view?Well the proposed drawing that Gavin has offered up,only means a planning submission if it is over 4 metres in height and looking at it I suppose it will be,apart from that he is not building in front he seems to have far more than 1 metre from the boundary,I suggest you use all the width you can.
That tickled me...but he is a local and a tree nut with the amount of trees on your boundary he will have you digging to OZ.
