i checked out both the A and B class today to make a comparison. The B class is huge for a merc, better feel etc, but reckon the FR-V takes it on the 6th making it more useable and future proof for me.
Plus the B class seems to have pretty poor real world user reviews, and hardly seen a word said against an FR-V
We looked at the FRV when considering our B class- did not like the plasticyness of the interior & the boxy shape. It did not have the high quality feedback that the B has.
We would highly recommend a B to anyone!
Also the FRV can not be specced up so much in terms of the optional extras, so will never be as luxurious inside. We went for the B turbo(sadly no longer available) and there was nothing that came close in terms of performance.
Yes, the FRV does have 1 extra seat, but how often will that extra seat be used? Which is more important; an extra seat used occasionally or the extra quality & comfort which will be appreciated on
every drive? Remember that because of the extra seat in the front, it means that the driver & partner will sit even further apart(this may be a good or a bad thing; depending on your partner- single passenger is
likely to sit next to the door) and there will be less arm/leg space on the door side for driver & passenger. Plus, there will be less garage clearance as it is a slightly wider car
Re: user reviews- Honda drivers may be less critical as they may be used to less...
Also, there are not many 6 seaters around- most are either 5 or 7, so someone buying an FRV is likely to be doing so specifically for 6 seats & hence is less likely to complain as there is no alternative....
If you are thinking of the FRV, you could also consider Fiat multipla(depending on age required), Citroen Picasso, MB Vito & I think one of the new Toyotas/Nissans has 7 seats?
