They are the same engine and gearbox but if I remember correctly I think the fuel pump is different in the 250d hence why they make more power if you map both carsive had a ring around and most are quoting 220bhp 500nm of torque which puts you somewhere near the 250d which sound about right as it has the same twin turbo engine and gear box.500nm is the same as the 250d and 220bhp is only 16bhp more so should be well inside the engine tolerances.
Ive read plenty on this and it seems you get about 250 brake and 490 ish ft lb of torque and it will make a massive difference.
