Any reccomended auto electrician in South Manchester / Cheshire for a dash cam job?
fab1975
Altrincham, Cheshire
C300 Hybrid (W205)
Hi there, after days of failed attempts at fitting a dash camera in my new C300 Hybrid, I decided to throw the towel and get the job done by a specialist.
I did manage to hard wire a couple of dashboard cameras on two other cars, including my previous one, a 2010 Audi A4, but I did not manage to make it work on the C300. I have located a live fuse and an acc. one, used the fuse taps, then reverted to the barbaric method of wrapping wires around the existing fuses, but I did not manage to get power to the battery discharge prevention device and now to be honest I am fed up.
Would anyone recommend a good auto electrician in the South Manchester / Cheshire area, please? Possibly somebody with specific Mercedes knowledge, as I suspect that there is some kind of setting that prevents power from being utilised by any "alien" device. It goes without saying that if I connect the camera directly to the cigarette lighter everything works fine.
Many thanks
Fab
fab1975 said:
Hi there, after days of failed attempts at fitting a dash camera in my new C300 Hybrid, I decided to throw the towel and get the job done by a specialist. I did manage to hard wire a couple of dashboard cameras on two other cars, including my previous one, a 2010 Audi A4, but I did not manage to make it work on the C300. I have located a live fuse and an acc. one, used the fuse taps, then reverted to the barbaric method of wrapping wires around the existing fuses, but I did not manage to get power to the battery discharge prevention device and now to be honest I am fed up. Would anyone recommend a good auto electrician in the South Manchester / Cheshire area, please? Possibly somebody with specific Mercedes knowledge, as I suspect that there is some kind of setting that prevents power from being utilised by any "alien" device. It goes without saying that if I connect the camera directly to the cigarette lighter everything works fine. Many thanks Fab
Did you take power from the fuse box under the boot floor? I have my möbius dash cam hard wired to a switched acc accessory fuse under the boot floor.
Thanks for your reply :-) Yes, apart from trying a couple of fuses combinations in the fuse boxes under the dashboard, I also tried the fuses under the boot floor, but they do not seem to work :-( If I remember correctly, I used fuses 406 (for yellow wire) and 450 (for the red one).
By the way, I had read your post about fitting a small cam in the top lights compartment and I really liked it. Did you upgrade to a Mobius at the end? Brilliant idea in any case :-)
Try ACS on 07791598849 and ask for Simon
top bloke - only guy I'll let touch my cars for the last 20 years.
Hanstons in Altrincham install the Roadhawk camera range.
They are a top notch M-B approved bodyshop with a great team of in-house technicians. LINK.
Thanks a lot for the advice guys! Actually Hanstons is quite close to where I live and their facilities are impressive, so I will call them and get a quote tomorrow.
This morning I have made a last attempt and followed a different method (Blackvue Install - MBWorld.org Forums) but even that did not work.
I wonder whether the hybrid models such as my C300 have some kind of weird power management system that prevents any non-authorised devices from draining power from the battery.
On a separate note, it would be nice if Mercedes offered the option to record footage from the 360° camera.
fab1975 said:
Thanks for your reply :-) Yes, apart from trying a couple of fuses combinations in the fuse boxes under the dashboard, I also tried the fuses under the boot floor, but they do not seem to work :-( If I remember correctly, I used fuses 406 (for yellow wire) and 450 (for the red one). By the way, I had read your post about fitting a small cam in the top lights compartment and I really liked it. Did you upgrade to a Mobius at the end? Brilliant idea in any case :-)
I did upgrade to a möbius, the picture quality is unrivalled. However I have moved the camera position as I decided to use a wide angle lens and this wouldn't fit in the small window area. I will post a pic of what I did.
Why not take a tap from the fag lighter?
Because I would like to be able to keep recording even in parking mode. Besides that, incredibly enough there is only one cigarette socket in my car (vs 3 I had in my 2010 Audi A4), which is not really suitable, as I would need to leave the central storage compartment lid permanently open.
I have a C200 on order and was thinking about running the cable under the passenger seat as I have been told the twin lids of the central storage compartment can still be closed with a cable run in from the back. If that is the case I will use one of the USB's located in there as a power source as my dashcam has a USB power connector on it.
