MikeInWimbledon
Hardcore MB Enthusiast
- Nov 8, 2014
- (Ex S211 E500, W212 E500, C216, S212 E500, W211 E500 5.5, W221 S500, S211 E500, SL500, S500, E55)
This product allegedly will enable me to stream Apple music (and podcasts) to my 2009 W212 using the MMI interface.
Anyone got any experience of using it? Good or bad ? I'm aware that it won't stream phone calls - that being done by the bluetooth already in the car.
Any thoughts appreciated.
Fair point that Bluetooth 5 is a better quality standard than early Bluetooth, but I’m wondering if I can use the Qualcom chip in this to automate the whole process using the MMI channel built into the car, AND avoid that extra bit of FM signal corruption.[/URL]
Might be of use, just link your phone and tune the radio to it.
Yes, I’d seen, and liked, the Integrative Automotive solution, but hesitate to spend that much, which is why I’m playing with the £35 that this Qualcom chip would cost to attach to the MMI circuitry..That's an interesting solution which I haven't seen before - it basically give the solution that I get in my wife's Fiat 500 and that seems to be the default for all the hire cars I was getting pre-pandemic.
I decided to go full Tonto on this and had Comandonline fit the Integrated Automotive system. It takes over the Comand screen so you get the full apps-in-the-dash experience; and that really makes the cabin seem much newer as a side effect. I now get and choose from Spotify music, Spotify podcasts, BBC Sounds, Pocketcast, TuneIn radio, Audible, etc whilst having Google Maps (yey!!) take me to my destination. Loads of other apps available and you can use Waze, of course, if you prefer.
It's very neatly integrated in the MB system and the Comand nudge wheel lets you spin through the menus. The only minor issue is that the connectivity drops occasionally and I have to clear the Android Auto cache on my phone - but it's very easy and doesn't apply to Apple.
This isn't my car but you get the idea. I'm really happy I did it as it does transform the whole in-car experience.
Just be aware that bluetooth quality is limited by the lowest common denominator. That is it will never be better than the the device with the poorest quality codec. Bluetooth codecs require both the sending devices and the receiving device to match so you will not get AptX-HD with the Airdual-330A if your phone does not do AptX-HD. It will fallback to SBC - which is pretty poor and about all that Apple phones will support - they have Airplay for higher quality streaming.Fair point that Bluetooth 5 is a better quality standard than early Bluetooth, but I’m wondering if I can use the Qualcom chip in this to automate the whole process using the MMI channel built into the car, AND avoid that extra bit of FM signal corruption.
Other themes make me hesitate as well, build quality, originality and future proofing against software and App upgrades
It’s the HK circuitry and speakers on the car that make me look at this. That and the French ban on using Bluetooth headsets in the car, which is bound to reach the UK one day.
But I take on board your recommendation. What’s the cost from Comand? Around £800 fitted?
Thanks ! Useful to know.Just be aware that bluetooth quality is limited by the lowest common denominator. That is it will never be better than the the device with the poorest quality codec. Bluetooth codecs require both the sending devices and the receiving device to match so you will not get AptX-HD with the Airdual-330A if your phone does not do AptX-HD. It will fallback to SBC - which is pretty poor and about all that Apple phones will support - they have Airplay for higher quality streaming.
I’m onboard with the general argument but I’m surprised you had problems with Siri. Using the phone cables or Bluetooth Ed to the CL or 3 series, it’s never really stumbled for me.It really is very good. The unit is £475-ish after MBClub discount. Fitting is around £200. I just told the Mrs that it was "400 and something pounds".....
The functionality is priceless; I'm driving the family down to Bordeaux this summer and simply having Google Maps on the dash for that journey alone is absolutely massive. No more phone mounts, no more trailing changing cables and, most of all, no arguments between me & the mrs.
I find that when I'm driving I can't do anything with the phone. Once I've set the nav and the playlist that's it until the next stop. We get into traffic, the mrs wants to change route/switch to Waze but stubbornly refuses to reprogramme my phone for some reason.....And as for changing playlists, forget it on a phone screen. This would cue a series of irritable arguments. A thing of the past now!
A great bonus is that for the first time in my life I have voice activation that actually works. I've never managed to get anything working for me be it Linguatronic, Alexa, Google Dots, whatever. In this install, I assume it's a combo of quality mics in the cabin and modern speech recognition but so far it's worked 100% for me. I just select the Mic button on the screen and say "Navigate home", "Navigate Halfords Alperton", "Navigate Lawson's Timber Camden" or "Navigate Paint Chip Brent Cross" and it gets it right first time. Extremely handy, and another series of navigation arguments dodged.....
And I should also mention the audio quality - it's extremely good and would sound fabulous through your HK.
As you can tell I'm a big fan.
Because Apple has Airplay they only support the basic SBC bluetooth codec. This is the lowest grade of bluetooth that was designed for just making phone calls work, not really good enough for music. Apple have never seen bluetooth as music transfer method.Thanks ! Useful to know.
I’m on IPhone 12 Pro, so hopefully not too bad, but that does help build the case for Airplay / car play.
Apple iPhone 12 Pro Bluetooth Audio Codecs
Apple iPhone 12 Pro Bluetooth Audio Codecsbluetoothcheck.com
Ah, OK, apologies for not getting that point properly before.
At this point i think I’ll punt £30 to experiment with the Bluetooth MMI adaptor, and then take it on from there, either through a wired connection or CarPlay.
Most of my listening is already just podcasts and streamed dreadful sound quality Spotify. With the HK circuitry and speakers I’ll have to see what path to take.
Mobile tech is clever, but we keep choosing convenience in preference to quality. Listening to Eric, Sting and Bach at home or out and about I’m always reminded that modern domestic audio is still worse than my Meridian set up of two decades ago
It’s curious, I still haven’t even tried out the CD deck on the new car as yet.
