Anybody know about TV aerial connections?
Discussion in 'OT (OFF Topic) Forums' started by BTB 500, Dec 5, 2011.
  1. BTB 500
    BTB 500 MB Club Veteran
    18,743
    Aug 7, 2005
    Berkshire
    Car:
    R129 SL500, W639 Vito 120, S203 C230
    We've got a rarely-used TV aerial point upstairs that doesn't work very well.
    The socket for the flylead was pretty loose so I fitted a new faceplate to see if that would help (only a couple of quid from Wickes). It didn't, but here's the weird thing. With the TV connected to the socket and the faceplate hanging loose I noticed that if I touched a screwdriver to the terminal that the centre wire of the co-ax cable goes to ... the signal improved hugely!
    Does that sound like the cable has a problem somewhere?
    It's not the end of the world as we only have an old (analog) TV/DVD unit up there for the kids to watch films on. But analog reception is OK on the aerial point downstairs, so I was just curious!
  2. Red C220
    Red C220 MB Enthusiast
    4,197
    Jul 30, 2011
    Surrey
    Car:
    2015 SL400 : 2017 S6 Avant
    My first assumption would be whatever it was connected to was pointing in the wrong direction/no longer there/has a severed cable.
    By touching the cable you've become the aerial and boosted the signal.
    1 person likes this.
  3. renault12ts
    renault12ts MB Club Veteran
    15,973
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    It does...you were a better aerial than the real one.
  4. OP
    OP
    BTB 500
    18,743
    Aug 7, 2005
    Berkshire
    Car:
    Thanks guys, will see if I can trace the cable. We've only got a single aerial, which is fine. There's a box in the loft that I assume splits the signal out to the various sockets around the house - will start there!
    It was only the shaft of the screwdriver touching the terminal btw. So about 3" of metal ... wouldn't have thought that would be big enough to act as an antenna??
  5. Merc Owner 2B
    Merc Owner 2B MB Enthusiast
    1,009
    Dec 3, 2009
    Leicestershire
    Car:
    2012 ML250 Sport BlueTec
    It's not just the screwdriver. You became the aerial by holding the screwdriver. No direct electrical connection is necessary for rf signals.
    Sounds like that cable may not be connected to an aerial at the other end.
  6. renault12ts
    15,973
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    ^ Agreed. Try holding your car remote key to your chin...it more than doubles the range at which you can open the doors.
  7. corned
    corned MB Enthusiast
    3,894
    May 2, 2008
    Living in error with Maude at Cap Ferrat
    Car:
    car
    ^ Indeed, but it's still not as good as wearing a metal colander studded with 6-inch nails on your head.
    5 people like this.
  8. Merc Owner 2B
    1,009
    Dec 3, 2009
    Leicestershire
    Car:
    If I see someone struggling with a remote I suggest this and, although I know it's true, can rarely get anyone to do it!
  9. Merc Owner 2B
    1,009
    Dec 3, 2009
    Leicestershire
    Car:
    Sounds like a scene from "Signs". :D
  10. OP
    OP
    BTB 500
    18,743
    Aug 7, 2005
    Berkshire
    Car:
    Yup I knew about the trick with the keyfob, but didn't make the connection!
  11. brucemillar
    brucemillar MB Enthusiast
    8,663
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    That is about the worst pun I have heard this year. Please tell me you meant it like that.
    2 people like this.
  12. corned
    3,894
    May 2, 2008
    Car:
    car
    +1 lol!
  13. grober
    grober MB Master
    27,656
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Analogue reception? You will be changing to Digital in Feb 2012?? So depending on the age of your YAGI array might be an idea to change to a wide band aerial while you are at it.:dk:
  14. OP
    OP
    BTB 500
    18,743
    Aug 7, 2005
    Berkshire
    Car:
    We've got a high gain antenna and receive Freeview HD etc. happily on our main TV downstairs - as mentioned, this is an old TV/DVD unit that the kids use. The digital switchover in our area is in April.
  15. artyman
    artyman MB Enthusiast
    2,106
    Mar 4, 2011
    Hampshire
    Car:
    C 200 CDI Sport
    That darned reminder that keeps popping up on my TV is starting to annoy me.
  16. OP
    OP
    BTB 500
    18,743
    Aug 7, 2005
    Berkshire
    Car:
    Well I had a little look ... and it seems the cable from that TV point runs down to a junction box at ground level rather than up to the loft. I think the previous occupant used a cable service, so I assume it was a feed for that. I'll have to investigate a bit more!
  17. corned
    3,894
    May 2, 2008
    Car:
    car
    Might be easier, not to mention cheaper, just to stand there with the screwdriver in the coax socket... :D
    2 people like this.
  18. johnsco
    johnsco MB Enthusiast
    2,034
    Nov 22, 2008
    Leeds, West Yorkshire
    Car:
    E280CDI SPORTS ESTATE
    Just place a new broadband aerial in the loft pointing at the transmitter.
    Run a new cable to the old aerial socket or to a "flying connector" to plug into your set.
    Should do the trick.
  19. Merc Owner 2B
    1,009
    Dec 3, 2009
    Leicestershire
    Car:
    Agree. Preferably run a single cable from the aerial and straight into the back of the tv, without the faceplate etc. This will give you the best reception.
  20. alan350CDI
    alan350CDI New Member
    13
    Dec 8, 2011
    Car:
    Mercedes C350 CDI
    You can get some pretty good faceplates, I have 2 at different ends of the living room depending on where the missus wants the TV on a monthly basis. They have gold plated terminals and I've got gold plated ends on the coax leads, we live in a terrible signal area and I still get great reception. Having faceplates means you can rearrange the room and not leave cable hanging out is all :thumb:
Share This Page
