BigMark
Has anyone fitted an aftermarket reverse camera to their C207, if so which camera?
I've purchased the one below on the advice of the seller but now it's here it's rather ugly and doesn't seem to fit the hole in the metal work.
Plus I know I need to cut out the blanked hole in the plastic trim to fit around it but the hole and the camera are not the same size so I'm not sure how it will look.
Hence why I'm thinking to use a difference camera such as the one below and just attach it the the plastic trim panel.
So any camera recommendations, links and photos from anyone that has done this to a C207 would be greatly appreciated.
I did contact www.commandonline.co.uk but at £799 it makes no sense on an older car.
Reverse Camera For Mercedes E-Class W212 Coupe C207 GLK Rear Factory Hole Backup | eBay
Guide lines help you easily judge the distance between objects and your vehicle. Specially manufactured to replace the existing number plate light allowing for easy installation without the need for drilling or modification.
www.ebay.co.uk
