Went to get a replacement battery for my other half's X-Trail via ECP, the battery arrived which is a standard size, however when removing the existing Nissan battery it became clear that the one in the car was a lot deeper and not a standard I had seen before:
White is original Nissan one, taller and narrower than the black standard battery I had as a repalcement.
The + and - Terminal connectors will not reach the standard battery, nor will the bracket which holds it in place, I need to return it back to ECP, however I need to know what to ask for instead. any one help?
I did connect up the replacement and it worked fine, I just cannot secure it in place correctly.
Cheers!
Cheers!
