Gilbertd
Ever since her indoors has had her SLK 280 (R171), the central locking on the passenger door hasn't worked and neither has the door mirror adjustment on that door (although it folds and unfolds automatically). A bit of digging and forum searching pointed me to the door control module having got wet and taking it out and opening it up confirmed that it had got corrosion inside where water had dribbled into it. One forum post I found reckoned simply cleaning the green bits up with contact cleaner and a toothbrush had got one working again so I tried that. No joy, just the same so I told her she'd have to live with it.
However, my temporary bodge on the noisy heater blower (R171 heater blower temporary (bodge?) fix | Interior) finally gave up so a new blower was required. I found one from a breaker and asked if he also had a LH door control module. He had so I bought that too. However, having fitted it, I found it was exactly the same. I took the RH module out and plugged it in on the LH door and although the Canbus address was wrong, the central locking worked and the mirror could be adjusted as long as I used the adjuster for the RH mirror to move the LH mirror. That confirmed that I had yet another module that had been dripped on. The supplier had stuck a warranty sticker on it so I couldn't open it up to see if it had corrosion in the same places but I suspect it did.
As a(nother) temporary fix, I've wired the door central locking motor to the glovebox locking motor so the door now locks and unlocks with the fob but not from the button on the dash (as that only locks and unlocks the doors not the glovebox). It also means that the automatic locking when driving doesn't lock the passenger door either. So it looks like the only options are to risk overloading the RH module by wiring the LH door lock in parallel with the RH door lock (which I'm a bit wary to do), buying a replacement module or finding someone that knows which component it is that fails when water drips inside them and replace it. Has anyone managed to trace the circuitry, identify what it is that fails and replace it?
