flying haggis
- Nov 8, 2011
- Location
- A house in Norfolk
- CLS shooting brake, SWMBO has B class
I do yes but as my tractor unit is 20tonne i think i'm covered
Benzmanc said:I do yes but as my tractor unit is 20tonne i think i'm covered
Got any pictures of this 20t tractor unit? I have artic's in all the time that only weigh 15t with trailer
Tony.
Here you go, 29.2t empty with its trailer
What's the equipment behind the cab?
HIAB xs 622 hi-pro. Will lift 3.35t to 14.7metres or 10.7t at 2metres
This is before it went on the road
People think that towing a trailer is literally about hooking it up to the car, yet the dynamics of a trailer should require a separate test in addition to the driving test.
There was absolutely nothing the driver could do to stop the snake, even though he was driving a Range Rover.
There was absolutely nothing the driver could do to stop the snake, even though he was driving a Range Rover. The weight of the tow car will have no impact on what the caravan wants to do.
Nice we occasionally use a guy with a similar spec HIAB but on a Scania 8 wheel unit i will have to get his on the weighbridge now to see what his weigh's just out of curiosity
Tony.
They don't have electric brakes trailers in the UK? Larger trailers usually have them here with smaller trailers using surge brakes.
Towcar weight does play a big part in stability, but so do things like wheelbase (4x4s are normally relatively short), rear overhang, suspension, tyre pressures, etc. And on the trailer/caravan - weight, noseweight, vertical CG, weight distribution, side area, tyre pressures, hitch type, etc.
