R129mine
Last year I removed the ARB on my R129 and did a quick sand down of the worst of the rust, painted it and put it back on.
This year I decided to hopefully do it properly:
Spray painted it in black for good measure
Ordered new bolts and nuts and 2x new inner and outer bushings
This morning I finally got around fixing it to the car the new bolts are slightly shorter than the old ones which makes mounting it a little harder but after 40 minutes of struggling it is now on.
Happy with the result, just a shame of the remainder of the suspension but that will have to be done another time
I also replaced the 2x horns and cleaned up the coolant expansion tank and did some other preventative rust treatment under the car by the wheel arches and the radiator supports as well as the front bumper mounting points. They all had light surface rust on it
Nobody will ever see it but I know it is there
I will now get the car on my small ramp and will treat the lower wishbones and centre support with POR15
- Sanded down the worst of the rust and old paint with an axle grinder
- covered it in deox gel for a few days
- sanded it down again
- applied hydrate 80
- applied 2x coats of epoxy mastic
