MB James
I've got a 2011 Viano 85000 miles and its making a droning noise at low speeds, seems to be when its warmed up, then when I'm turning right or reversing. I thought it was coming from the rear, suspension or electronic suspension adjustment. But now I think it could be more to the middle.
Would this suggest prop shaft or prop shaft bearings? Is this a common problem?
I had an 06 Vito that I had to replace the propshaft on. Cant remember if it was a similar noise.
Mercedes Bath had a quick look at it but had no idea. Mind you they didn't check the prop shaft.
I'm a chauffeur and the Viano is booked all next week. The noise is intermittent but quite loud when it happens. Need to get it sorted quick. Any ideas?
