Skd884
- Sep 13, 2017
- c180 w204
I will be shocked if that price includes no extras, its not possible.The discs and pads all arrived, were the real deal and were fantastic. Installed in a couple of hours and feel brilliant. Definitely a bargain!!!
Yes my car is due for a Service A - which is £830.10 without additional items. The reason I say it’s a very expensive “oil change” is because when I read what is done on a Service A - it appears to be a oil and filter change and a look around the car. If I want the plugs doing too, the total cost is basically £1,000.
Please correct me if I’m mistaken with this, as I’d be happy if they were actually doing more than that for the money!
See here for what the Mercedes website tells me;
Key Features of Service A
Change engine oil and oil filter (not applicable for electric vehicles) Check charging cable and vehicle socket for mechanical damage (Hybrid & Electric) Check brake fluid level Correct and note down tyre pressure Check/correct spare tyre pressure (equipment specific) Check TIREFIT tyre sealant (equipment specific) Check first aid kit Check luggage compartment illumination for proper operation Check/correct windcreen washer fluid Check lamps in the instrument cluster and interior illumination for proper operation Check ex-factory driving aids (equipment specific) Fill up or replace vial of perfume atomizer (equipment specific) Fill up Ad®Blue tank (equipment specific, after consultation with customer) Check coolant level Check all visible parts in engine compartment for damage and leaks Check visible area of auxiliary belt for wear (if applicable) Check all visible parts of vehicle underside for damage and leaks Check condition of steering and tie rods Check condition of front axle and front axle ball joints Check condition of propeller shaft and flex disks Check condition of rear axle and rear axle ball joints Check condition of suspension struts or shock absorbers and springs Check tyres for damage and crack formation
