- Oct 4, 2019
- Location
- Guildford
- E250 Avantgarde Estate, Alfa GTV V6, Vespa, Ducati, many bicycles...
Hello all
Well the good news is my S212 rear suspension doesn’t seem to leaking anymore (after new air bags, new compressor, new air lines and new valve block)
But the other day the offside suddenly pumped itself up to full extension and the malfunction message appeared. I immediately thought aha must be broken sensor arm, so duly ordered a pair. I then had a look and the arms on both sides are intact, the offside must have been replaced already as it has the newer metal arm. During the process of jacking both sides the car seemed to level itself out and then drove ok for a day, so I thought maybe just a glitch.
Then today it did the same pumping right up With the malfunction message.
I assume this is pointing to a failed sensor on the offside? I’ll check the connections tomorrow but anywhere else worth investigating? Just as I thought it was fixed!
cheers!
cheers!
