BDE1V
- Apr 27, 2006
- CLK 320 (w208)
Ive a new fault on my W208 CLK regarding ASR, BAS then ABS Warnings.
I've had to replace the Brake Switch a few years ago which would give ASR & then BAS faults as soon as the brake pedal was touched after switch on.
I've had the brake pedal switch out & checked both it's switch contacts with an ohmeter & everything is fine regarding switch contacts.
This fault is different in that the ABS & the combined BAS,ASR Warning lights don't go out once the ignition is turned & the engine started. The Display then indicates the three faults in sequence.. I've never seen the ABS Light on before so i'm assuming the fault is related to this.. Battery voltage is normal & alternator charging ok, so nothing to do with low voltage etc.
Anyone know where the ABS Unit is located on this so model.
Any help would be appreciated
Regards
Brian
Regards
Brian
