Satch
- Nov 24, 2003
- Location
- Surrey
- S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser
I am very, very annoyed.
Many W211/S211 turbo diesel owners have noted that their miles between services are a lot lower than expected and differ from that of others. I recently had a “C” service and instead of the 12,500 miles start point (20k km) expected found that I ended up with 9200 odd (15k km) and others have suffered similar effects.
So I have delved. There is a user (i.e. Dealer definable) setting in ASSYST to distinguish between “conventional” oil and full synthetic oil, “MB 229.5” per my system. However, the published spec for my car is MB 229.3 which is something my ASSYST does not have a setting for! This directly impacts upon the miles to next service.
So I changed the setting to MB 229.5 and yes, a further 5k km appeared. Forgive me for being bitter but for 7.5 litres @ at £11.00 plus VAT per litre for Mobil 1 Turbo Diesel I see nothing conventional in that. It meets both MB 229.3 and MB 229.5 unless someone at MB UK or Mobil wants to tell me different.
Now there are a number of possible reasons for this and none are particularly welcome, especially for high mile users At the very least confusion exists over oil specs and ASSYST is thus unable to do what is supposed to. In effect MB might as well set a routine 15k km (10k mile) oil change with damn expensive full synthetic which per the MB 229.5 spec is supposed last 30k km. (20k km is the spec for MB 229.3!)
I will be posing a few questions on Monday of both my dealer and MB UK and would suggest that others might care to do the same.
If you want to try this do so at your own risk. Need to be 100% sure you have the right oil spec. in the engine and this is only for a W211/S211 as far as I know:
It is under Item 13 in the “Additional Work “ menu. You get into that after pressing the odometer reset button for 5 seconds whilst in the main “time/miles to next service” details (the spanner!) menu that is behind the temperature display.
Annoyed? No, in fact I feel cheated
