ATF change cost....
clk320x
Hardcore MB Enthusiast
UK
Tesla Model S, Model 3 LR, Model X /// Previous: Jaguar XFR, Mercedes E320 CDI, C32 AMG, CLK 320
How much are people paying for ATF changes?
car is a W212 with the 5 speed 722.6 box
£250 ish max I would say.
5L is £40... dunno how long it would take or what else is involved though
About £200 from indy if electrical plug is changed. Bit less if plug ok.
5 litres is not enough for a full ATF change that should include torque converter and cooling lines. But removing 5 litres of old and replacing it with new (including filter) is better than doing nothing.
Any decent gearbox specialist company or MB indi could do this for £200 or even less if you agree with them that you will buy the consumables. Depending on age and mileage I would recommend getting the (cheap) TCU plug changed at the same time. Loads on here and YouTube on this procedure. Insist they drain the torque converter and cooling lines, they will possibly charge more but it is a more complete job than just draining and removing the sump. Remember that its not just mechanical gubbins that run in the oil, the electrically operated solenoids and conductor plate are also swimming around in the same oil.
Change it. :thumb:
Had my S204 C220 done not so long ago, full BIFTA gearbox and TC plus filter, local indie, £400.
Why not check out fedauto.co.uk? Honest John recommends them. Indie automatic tranny specialists.
Planning too :)
